Unknown code?
93nighthawk
Mitchell, SD
I pulled codes today to see what is now causing the CEL to come on. Here is what I got:
KOEO
111 System Pass
111 System Pass (twice?)
117 Ect indicated 254degF Circuit Grounded (What the?
217 Coil 3 primary circuit failure (Great, new coil?)
317 (???)
617 1-2 shift error
717 (???)
917 (???)
KOER
632 Transmision Control switch (TCS) circuit did not change states during KOER
I checked Chilton's and Shotimes.com for the code #'s and came up empty. Just to make sure, I pulled codes again and got the same numbers. Any and all help diagnosing would be greatly apreciated.
Eric
There is a single separator pulse after the hard fault codes. The codes are also repeated. That is why you saw the "111" twice. You should also have seen the series of memory codes twice. I'll bet your memory codes were 172, 173, 176, 177 and 179. Since this covers both banks, it looks like an engine control situation rather than an O2 sensor problem. You should run the test again and double check your codes.
See this site for a good description of what to expect when you run the EEC test.
http://www.dalidesign.com/hbook/eectest.html
http://www.dalidesign.com/hbook/3digit.html
93nighthawk
Mitchell, SD
Thanks Sdpatt thumbs_u , My mind went to mush there for a second. I have been pulling codes on my wife's 95 Mystique 4 banger trying to diagnose something, forgot about the two banks. Well now both sides have 111 after clearing the memory and driving it for 100mi.
Eric
