snowwind1990
Cooling system:
Radiator may be clogged:
flush it til it is clear water coming through it. Refill with 50/50 coolant(green) and distilled water. Reservoir should also be thoroughy cleaned at the same time..remove it to do it. So far you have needed two socket sizes, you know the stop-**** is how you let the coolant out?.......this all takes about 1 hour.However, burping the car to get the air out could take 1/2 hour additional, squeeze the big upper hose to see bubbles in the neck of the rad.
Drive Car.
Still too hot?
Change t-stat: Motorcraft only replacement, available at Autozone..no substitutions please. Remove large hose, the one you squeezed! Screwdriver needed to remove clamps.
Drive Car.
Still too hot?
Change t-sensor: Again, just to left of big hose, and screwed into throttle-body..
Still too hot?......probably not!
Try one thing at a time.......do not change all at once or you can't gauge the improvement each time and eliminate the bugger-boo!
M
Drive Car.
Still too hot?
Drive Car.
Still too hot?
M
