SHOtimer
#2910
Ok, I have a choice of two PS pumps now that I am putting my motor back in.
One is from my '95 with 165k on it, and pours nice clear red fluid.
Second is from a '93 with 132k on it, and pours blackish fluid.
Neither leak.
However, if i put them next to each other and turn them the second one (the '93 one) has a much tighter bearing and just a tighter feel in resistance to turning it. The '95 doesn't slop around, but you can definately tell a difference in how the '95 one is not as tight and spins a bit easier.
I assume the '93 will be a better pump to install, but I wanted some other opinions.
Thanx, Doug
Neither leak.
Thanx, Doug
