twisted the scrader valve
sho4life
midwest
i might have an easy fix to a stupid mistake. i was tightning the scrader valve and accidently turned the top part and now it leaks, is this why my car hasno power.. it runs but has no power. no backfires or pops. no cels, replaced all sensores. one other possibilty is that i have a bad dis ground. i have no crossover plenum bracket and the big thick grounding strap is located by the throttle body on my car. also there is a plug which i cannot find the other end for. it is grey square and inside it has a three or 4 pin cicrular with a red strip on top..
sho4life
midwest
ok its not that valve with the black cover its the one next to the dis next to the one by the fuel pressure regulator? not the one with the hose.. i really think it is a fuel probroblem. its not smoking or popping . but i also dont have a plenum crossover bracket so maybe my dis is not grounded properly because my main thick intake ground strap is on the other side by the throttle body.
sho4life
midwest
i mean i can see it. how much will this affect pressure?
no cel, yes i replaced the o rings and seals on the injectors. i just found out i have no gas cap... what will that do to the engine ?
ill get some carb cleaner and check vacuum
