MLNIUMFLKN
I'm having some trouble with my Tweecer BIN file which was created from my SHO Shop LPM. It has problems with cold starts. What puzzles me is that I don't have this problem with the SHO Shop LPM. I only have the problem with the Tweece BIN file that was created from the LPM read. The Tweecer guys couldn't explain it either. Maybe some of the data from the LPM wasn't converted correctly or completely into the Tweecer BIN file. I don't know. I was wondering if anyone wouldn't mind sharing their Tweecer CCF's to use a starting point for a future tune. Here's my setup:
95 MTX, 3.2L, 9:1, High Flow Heads, 3-angle Valves, JE Forged Pistons, Stage II Cams, BBB's/EH Intake Runners, 68 mm TB, Vortech V-2 S-Trim, 2.87" pulley (14 psi), front mount air-to-air Intercooler, Water/Methanol Injection, 80 mm MAF, 47 lb Injectors, Walbro 255 lph, SHONut FPR, TwEECer RT, tech edge WBo2, MSD Knock Alert, SHO Shop Headers, Off Road Y-pipe, 3" Exhaust, Quaife LSD, DynaMax Clutch, 8 lb Flywheel, Short-Throw Shifter, SHO Shop Comp Suspension, 13" Baer PBR's, and 17x8" SSR Comp's.
