Marccus
I'm replacing my brake lines and I can't loosen one of the tube nuts on the steel lines. :headbang:
It takes an 11 mm wrench and I've huffed and puffed and tried to take that @!#$# thing off. I've tried Wurth Rost Off (just like PB Blaster but better IMHO).
I've started to round the nut off.
If that happens, should I just resort to ViseGrips.
I know I'll ruin the nut but ...
Anyways, is the only way to replace a tube nut, to replace the whole assembly because you can't take slide the nut off the flared end?
