Trunk relase handle lock
etc1006
Baltimore, Md.
How do I replace the lock on the trunk relase handle. I got a whole lockset from Erik (Thanks!) and I can't seem to figure out how to get the bracket out to remove the lock... TIA
SHObill
'The Collector'
Rochester MI-48307Detroit
remove the screws that hold the plastic trim on the sill. pull it out of the way a bit remove 2 #3 philips screws & u can pull the assy. up some to access lock cylinder.While your there now take a dremmel cutoff wheel & cut off the 'L' shaped spring loaded metal finger that holds the lock cylinder down so u'll never need a key anymore !!
