i'm runnin 2.5" single pipe from the y-pipe rearward, and when i switched from a stock cat-back to that, low end grunt was much more noticeable. i doubt i'll ever run duals again, not to mention the 30ish lbs weight savings on the ass end of the car.
well in ill maybe go with 2 inch or 1 3/4 since the original his 2.25 1/38 would be more then enought for 3 cyl and would make some back pressure
You might want to do some reading on exhaust theory. You don't want back pressure (i.e. a restriction). You want high exhaust gas velocity with a minimal pressure drop.
having a moderate ammount of backpressure helps in cylinder scavenging and therefor velocity.
True duals for sound is a really, really bad idea.
Unless you want your car to sound like shit. Or a chainsaw, or a snowmobile, or a swarm of bees.
