Tried search
SHONUT91
Cameron,Mo.
I am trying to locate a part# and supplier for the rod bolts and nuts for the 3.0 and I would presume the 3.2 would be the same. I tried the search and after about an hour of reading alot about rod bearings and bolts still no # or supplier. Thanks for any and all help in advance.
SHONUT91
Cameron,Mo.
I am in the process of changing my sons rod bearings and one of his rod bolts has damaged threads so I am going to replace it now while i'm in there.
AREA 91
PA SHO SHOP
Area 91
Several member's on here have used ones.
Post in the Wanted To Buy section.
SHONUT91
Cameron,Mo.
I realize that I can find used ones,I would like to find a part# and supplier for new ones if at all possible as well.
AREA 91
PA SHO SHOP
Area 91
Item Part number
Timing belt guide, crank E9DZ-6K297-A
Timing chain guide, RH E9DZ-6K297-B
Timing chain guide, LH E9DZ-6K297-C
3.0 Con rod, cap, bolt, pin E9DZ-6200-A
3.2 Con rod, cap, bolt, pin F3DZ-6200-A
3.2 Oil Pump F3DZ-6600-A
3.0 Oil Pump to Block Gasket (obsolete) E9DZ-6659-A
3.2 Oil Pump to Block Gasket (obsolete) F3DZ-6659-A
Oil Pump Pickup Gasket (obsolete) E9DZ-6626-A
Valve Guide E9DZ-6510-A
Intake Valve Seal E9DZ-6571-A
Exhaust Valve Seal E9DZ-6571-B
3.0 Ring (Ford) E9DZ-6148-A
3.2 Ring (Ford) F3DZ-6148-A
3.0 Crankshaft E9DZ-6303-A
V6 3.0 MTX Intake Camshaft RH E9DZ-6250-A
V6 3.0 MTX Intake Camshaft LH E9DZ-6250-C
V6 Common Exhaust Camshaft RH E9DZ-6250-B
V6 Common Exhaust Camshaft LH E9DZ-6250-D
V6 3.2 ATX Intake Camshaft RH F3DZ-6250-A
V6 3.2 ATX Intake Camshaft LH F3DZ-6250-B
Oil Filler Cap EC-743 F3AZ-6766-B
3.0 Engine Dampener/Pulley E9DZ-6B321-A
3.2 Engine Dampener/Pulley F3DZ-6B321-A
Oil drain plug E9DZ-6730-A
V6 Main (outer) bearing E9DZ-6333-A
V6 Main (middle) bearing E9DZ-6337-A
V6 Main (thrust) bearing E9DZ-6334-A
Clevite Bearings
Main Set MS-1773P
Rod upper/lower CB-1435P
Engine to TB PVC hose E9DZ-6A664-A
Oil gallery plugs, 1/4" drive recessed head E9DZ-6026-C
Hastings 3.0 Rings 2C4650
Hastings 3.2 Rings 2C4881
Valve cover bolt (inner) and gasket (pkg of 6) E9DZ-6A548-A
Valve cover bolt (outer) and gasket (pkg of 4) E9DZ-6A548-B
MTX Piston pin clip E9DZ-6140-A
ATX Piston pin clip F3DZ-6140-A
V6 Head bolt E9DZ-6065-A
MTX Timing belt tensioner pulley spring E9DZ-6L273-A
MTX Timing belt tensioner pulley stud E9DZ-6K289-A
V6 Camshaft belt sprocket E9DZ-6256-A
V6 Camshaft chain sprocket E9DZ-6256-B
V6 Oil Cooler F2DZ-6B856-A
V6 Oil Cooler Bolt E9DZ-6L626-A
V6 Engine Tool kit T89P-6000-A 303-S340
3.0 Engine Dampener/Pulley bolt E9DZ-6A340-A
Valve Spring E9DZ-6513-A
