lithy
Ok bought a 95 ATX SHO sold as having a bad trans and a bad shifter. The shifter lock isn't working right, but before I worry about that, I'll worry about what I'm going to do with the transmission.
It seems to only work in Reverse and 1st, but under some driving it seems like I can get it to clunk into 2nd. After a short drive to warm it up, I stopped it when a CEL came on.
It seemed like the trans fluid was leaking from somewhere and smoking off on the exhaust, so I was getting some light smoke from under the hood.
I figure I can limp it to an AutoZone or the like and get whatever code it threw pulled. But I figure I'll ask here to see if there is something like a CPS or some other sensor that could be bad and causing the trans to not shift other than the whole trans being bad.
Thanks
Thanks
