jcgrumman
Here is what happened;
I was accelerating full throttle, from a full stop, using the paddle shifters, when the car failed to up-shift properly. I fully lifted off the throttle as the rev-limiter kicked in. As the rpm's dropped towards 1000 I gently added throttle only to realize that the car appeared to be in neutral. I pulled the paddle once more with no effect. I then put the car into D and still nothing. I pulled to the side of the road, put the car into Park waited a few seconds and then shifted into Drive and the car was still in neutral. I then put the car into park and shut it down. After restarting, the car functioned normally.
I don't know why the car failed to up-shift. I know that I activated the paddle plenty early (~5,500 rpm), but I may have tapped it too gently.
James
James
