Trans Rebuild
SHOTUNES
Ohio
I will be rebuilding my 93 ATX soon. I have a few minor mods hopefully more to follow. If i keep my trans and rebuild it what is the transgo kit # for 93 ? You would not use 94/95 kit since I'm upgrading? What about TC? Should I get the same one or what is the next step up and what would the difference be? Like to beef it up as much as possible while it is out.
SeanMc
NoMoSHO
Not sure the part number for the shift kit, but you want the '94-95 parts. As far as t/c, unless you are higher compression, there is no reason to change since the flash stall is set at 2400rpms.
