MOSHO92
Well, here is the issue.
Ever since I installed my southbend TZ clutch and Fidanza flywheel I have been having trouble shifting quickly at high rpms. I also have been dealing with a "crunchy" clutch feel. (see: nevermind, the thread is gone)
Recently everything has become more severe:
-I can barely get into gear from a stop. I have to move the shifter back and forward and all over the place to try and find a gate that will let me in. Then I can put it into first. I do that, or if I'm in a hurry I just push HARD and it crunches into gear (not really a grind, more of a crunch).
-Something makes a very strange noise as I depress and release the clutch pedal (even with the engine off). It is hard to descibe: Feels like something is rubbing ******* the quill shaft or something is sticky on my pressure plate. Sounds like....Crunching!
So what do you think it is? Clutch or Trans? If it is the clutch I will be upset...it is only ~10K old.
Thanks
Thanks
Thanks for the advice. I will come back to this thread (or start a new one) when I am ready to do it. Then I may need some advice about how to spot damage, wear, etc. in the trans. Thanks.
