I assume you have a 93-95 ATX? I haven't done it, but I assume any AXODE/AX4S from a Taurus, Sable or Continental will bolt up to a SHO. Are they different? Definately! The SHO Tranny has a different Sun Shell and clutch packs with more plates. Numerous other internal differences also.
Here's what I did. Got a 94-95 factory rebuilt SHO tranny from the dealer for $1500 and put in the Shift kit. Check out the how-to article
http://www.shoforum.com/shiftkit.htm Some of the pics are a little dark - I need more light in my garage.
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, High Rate Linear Springs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/45s on 16x7s
Very Low Very Fast
[This message has been edited by ThrillSHO (edited 12-02-2001).]
