tranny from boneyard
SHObra
Quarryville PA
would you trust a tranny from a junkyard also is there any way to check it out before i would buy it i found one for 250 dollars but i am scared now that i know about diff. pins the junkyard is pulling it out for me but is there anyway to be sure it will be good thanks alot Jason
89 Gary
Millbury, Ma.
I paid $900 (80,000m) earlier this year with a 6 month warranty. Yours must be warranteed? Check everywhere for cracks and if oil has particles (metal) in it. You could chance it and just change oil (red line) or have tranny guy take apart to check and maybe even install the sho shop "rebuild" kit depending on your preference. Make sure to change axle seals/rear main seal and use new bolts, etc if you can. I did all that also with a new sho clutch/bearing and it was $950 on top of tranny price. Good Luck
drivinhard
Gainesville, GA
The only way to check it, is the pull the case halves apart. From there you'll have to pull the gearsets/shafts out, then pull the diff out. (If you have a helms it walks you through it). You can punch out the locating pins with a 5/32 punch (make sure you have a long punch so you don't tear up the plastic speedo ring), inspect those and then you can remove the actual pinion shafts.
For the roll pins you'll want to look for pins that are bent, or starting to bend or sheer. For the pinion shafts you want to looking for galling or severe wear.
I doubt this is something a bonyard is gonna let you do before you buy it. But you can always check after you buy. If you need diff pins you can replace.
SHO NUT has good prices on tranny parts on their website, but Ford just recently made the diff pinion kits obsolete, I don't know if SHO NUT is still selling them. I grabbed the last 3 sets I could get my hands on, and my local dealer said a dealership in OR had 1 or 2 kits left. I could get their info if you need to order them. Dealer list it's about a $42 kit.
good luck,
mark
drivinhard
Gainesville, GA
$250 is a good price for a somewhat rare and getting rarer everyday MTX-IV...
White 92
SR71SHO - racer '89
