Tranny cooler?
Rogue10186
The Cajun
Louisiana
The radiator on my '93 3.2 ATX blew out on me a few months ago, so we had it replaced, and now I'm not sure if I have a tranny cooler inside or the better one that's mounted outside. Regardless, I want to get an tranny cooler upgrade to keep my tranny nice and cool during the summer.
Infront of my radiator, between the radiator and the bumber there is a small black finned box that is about 4' x 21' there a two rubber lines that come off either side of it.
On it are the words:
FORD
B3
F3DH7A095AC
Magra Development &
Manufacturing
Would this be the tranny cooler, and if so which side is the input, and which is the output? And where should I put a tranny cooler upgrade?
Also, Is it possible to clean the EGR ports inside the intake without taking the intake manifold all the way off, and just unbolting the throtle body?
DoC-JoneS
Newport News, VA
you have found your auxiluray transmission cooler. the side closest to the tranny is the out while the side with the line coming from the radiator is the input side. replace the factory cooler with an aftermarket one with the appropriate ammount of cooling line. hayden #679 is a good choice :thumb: . avaliable from your local autzone for $69.99 or from many SHO vendors for varying prices...
