toe settings
Washington
I was just wondering if someone could tell me the toe specification front and rear for a gen 2. should it be 0 degrees?
0 is okay according to the factory specs, but I have found that the rear tires will cup with 0, so you need some toe-in, more depending upon what your camber is (the more negative camber, the more toe-in is required.)
