To sieze or not to sieze, that is the question
Markus
Ottawa, Ontario, Canada
I'm looking for opinions on whether or not to apply anti-sieze lubricant to the spark plug threads. My internet search proves unconclusive. This is what I learned
1) Always use lubricant to ensure spark plugs can be removed later.
2) Never use lubricant because the plugs may become over torqued.
I have never used it in the past and have never had a problem removing plugs.
Your thoughts?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
I've never used anti-seize on spark plugs, and some even come with them. It always seemed to me that the anti-seize would hinder the spark plug's ground path, and increase the chance for a misfire.
I'm sure someone else will have a different opinion than me, but I say no anti-seize.
Always use anit-seize grease on the spark plug threads in an aluminum head. Always.
rangerj
Brunswick, Ohio
Markus,
You would only have to deal with a sparkplug that has become siezed in an aluminum head once to know that anti sieze compound is a MUST.
The two different metals will become welded due to "galvonic corrosion".
If you are concerned about electrical conductivity you can use a compound called Kopper Shield. You should be able to find it at auto parts stores.
If not, go to www.eastwoods.com. They sell it. It is about $9 for a small bottle, but it is great for electrical connections, and has anti-sieze properties.
Like the man said, "ALWAYS use an anti-sieze compound on spark plus that are going into an aluminum head" ALWAYS! rangerj
I use the kopper stuff. Got to be some of the messiest stuff around. Right there next to expanding foam wrt getting it all over you.....
The metal washer and metal-to-metal thread contact provide all the electrical conductivity needed for a zero resistance circuit path. Anti-seize is NOT dielectric grease. It will conduct current due to its high metallic content.
<small>[ May 08, 2003, 01:44 PM: Message edited by: sdpatt ]</small>
bmytych
