Tire opinions! quick!
SHOspazz92
Banned
Triad Area, North Carolina.
Guys, Need new Tires ASAP. I got 3 tires in mind, Tell me what you feel are the best.
First is the NITTO NT-450 Extreme performance Tires, 215/55/16. Good tires, Had them on the Silver 92, Did fantastic.
Second:Yokohama AVS ES100, 225/55/16's. Have never had a yokohama product, but I hear they work wonderfully. Also, Is 225 a Safe width to run on a Slicer?
Third : Kumho Ecsta Supra 712 225/50/16, Also, Never had any experience with khumo's, But have heard good things.
The only reason I put this thread in this section was for traffic, and I need to order these tires by tonight, Your input is appreciated!
-Sam
DHMag
Free At Last
InCahoots, Texas
the Kumhos are junk, the Yokos are sticky but wont last you more than 10K miles. no experience with the Nitto, though i nearly bought them.
SHOtimer
#2910
Santa Clarita, Ca
I'd go for the Nitto's or the Yoko's, I've heard negative things about the Kumhos, but not the othe two.
Doug
twr
whoohoo
half-way there, I think.
I have a set of AVS ES100 on the Outlaw, love the grip, but they are wearing quickly... but that might have more to do with my heavy foot and 9psi of boost. I also have a set of Nitto 555 extremes on another set of rims, I like those tires a lot, good traction, but they get greasy if pushed hard. Not sure how the 555's compare to to the 450's, but I would buy them again.
Rickabod
Representing da U.P.
Brimley, MI
i had 450 nittos on my CSVT when i first got it, they were ok for a cheap tire (around $50 apiece the previous owner said). i had some kumho's on my old stang and they burned up quick, i would go with the yoko's.
jedhead
westminster,ca
225 will work ok with slicers. I had 225/50's on my slicers for many years. I have had both the yoko's and kumho's. IMHO the yokohamas are much better. Great turnin and sticks well. I have 10K on mine now and I believe I will get the typical 25K out of the tires. Rotate the tires frequently and keep a good alignment.
bob
Yamaha V6
SHO Enthusiast
Rhode Island
I currently have the Nitto 450's on my 911. Quite honestly, I think they're one of the WORST "performance" tires out there.
712's - very sticky tire, quiet, wears quickly
ES100's - best choice IMO on the 3 you mentioned.
Personal advice: Toyo Proxes T1-S (or the newer T1-R w/ better rain channeling), or my new fave, Kumho MX. As always, I recommend a 3-season tire w/ Blizzaks on a spare set of slicers / similar for winter only use.
Yamaha V6
SHO Enthusiast
Rhode Island
They'll look like training wheels.
225/45-16 = 23.97" diameter
215/60-16 = 26.15" diameter
Want an additional 1.5" of fender gap? I didn't think so.
Try 225/55-16 instead of 45 series, it's much closer & works well.
SASHO91
Zoom Zoom
San Antonio,TX
Kumho= ok tire, if you can find them cheap....
nitto= overall good tire
yoko= overall ok tire....
your choice....
for something thats gonna last, or something to burn up through for awhile....
IMO the nitto will last the longer of the 3.
but i would still stick with what i got... i like them alot...
maybe a different tire from yoko would be better..... ??
its your choice though....
wuzzzer
MN Moderator
St Cloud, Minnesota
SHOspazz92 said:
Thanks guys! :thumb:
I decided to go with 225/45/16, How do you think they will look at stock heigth? or should I say with with 50's?
Haven't you learned anything with your 2000+ posts here?! :biggrin: WHY did you pick that tire size???
Jonny Cash
Good boy
Hollywood, FL
Unless your slamming that car to the ground I suggest you dont go with 45's.
This was my red 94 with brand new Proxes. 215-55-16's. I wanted to go 225, but they were like 25$ more each. And the gap in the wheel wells killed me.
I would take the advice. My suggestion would be 225-50/55-16's. Look into the Yokohama Avids. Wont last too long, but they are awsome all around tires.
[/IMG]
Jonny Cash
Good boy
Hollywood, FL
your choice....
Im just curious why you say the nitto's are superior to Yokohamas. I think the Yokohamas are some of the best street tires out there. I had some Paradas, and they were awsome on DRY pavement.
K-Dawg
Treasure Coast, FL
Avon Tech M500, Fuzion ZRi, GoodYear Eagle F1 GS-D3, Kumho MX, or Yoko AVS ES100.
The Kumho 712 and Nitto Nt-450 are both dated tires IMO and you can get a better tire for the same money.
225/50/16 or 225/55/16.
SHODOGG
Crowd Control
SHOCAGO
Dude, 225/55/16 is the only tire Id go for on a slicer, unless you plan on tracking it a lot then 225/50 but then your speedo will prob. be a bit off. I love every set of 225/55's Ive ever bought.
jedhead
westminster,ca
I liked using 225/50-16. The slightly shorter tire help the car accelerate slightly better because the overall final drive ratio is a little shorter. 225/45 is very short and you will have some tire gap.
Bob
NJSHO
Clean Your Shorts!
NJ
I think 225/50 even has to much gap even with eibachs. On the other hand its probably a lighter tire and decreases rotating mass. Ive always had 225/55's and I love em'. Avon's are what I am running now but my next set will probably be p-zero nero's which are soemthing like 6 lbs lighter per tire than the avon's.
