TankII
My mods will, and if I'm competitive, I will be honest about my mods.
TankII
TankII
My concern with the RS3 is the softer compound, and they should heat up faster. The 615(iirc) azenis would get greasy and accelerate wear on a track, due to the soft compound(and being falken naturally)
And otherwise completely agree with you on setup and the life of star specs, I easily had 60-75 autox runs(alot at grissom+75% of time sprayed off), close to 150 drag passes, and between 20-25k miles on the set on the redline(which weighed 2990) So its close to the weight of sho's.
If you're dead set on staying with Slicers, you're going to want to go to a 225/50/16 for autocross. IMO, with only driving 4,000 miles a year, you would be best with the RS-3 or Star Specs.
I agree. Although I got <10K miles on the RS2s & the 615s, they were each on the car for near 3 years, as the car didn't get driven much.
Since I use the white '89 for 1K round-trips for work, I got the evo V12s.
Honestly, the evo V12s sacrifice little (relatively speaking) over the RS tires. The evo V12s were the best tires I've ever run on a SHO. OTOH, I never had 17x7.5" wheels on my other SHOs, either.
