Timing chain replacement
Riverarat563
Iowa
About to start a timing chain replacement on a 14. Is there a way to tell if the chain is bad before taking the timing cover off? I have a poor idle and throwing codes for cam crank correlation on banks 1 and 2. Looking at ordering a cloyes set from rock auto. Anyone know if there is a difference in the 3 cloyes sets they offer as far as quality. One comes just chains guides and tensioners, next one adds gears and final one adds the water pump. Also anyone have a recommendation to source phasers and oil pump? Also any other input advice or help os greatly appreciated.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Boundary makes billet oil pump gears. Tasca or Fordpartsgiant is where I would look first. Perhaps worth replacing both cam shaft position sensors as well?
BadBrad
My water pump crapped out at around 75k miles; shop swapped out the chain and its fixings at the same time. Very disappointing (on a car that is very well maintained) - by the way.
Riverarat563
Iowa
Had found a nice write up on the chain replacement the other day and now I cannot find it. Anyone know have a link to it? I believe it was 2 pages long. Was gonna print it off as a refrence
gwrabbit
Wisconsin
I know it's an F150 video but I would assume it would be relatively the same process since we have the same Engine.
If you're doing the timing chain, do the water pump, phasers, tensioners, the whole 9. The last thing you'd want is to do the timing chain and then have the water pump shit out shortly after.
My shop used the Cloyes timing kit (90738SB) and the water pump (Sondalle)
