Timing Belt Tensioner Bolt, Snapped.
93EmeraldMTX
East Lansing, MSU
yup, its snapped. Not sure what i messed up, i might not have tightened it down all the way or something, im not sure. it went probabaly 50 miles after a replaced the water pump and timing belt before it died.
<small>[ December 21, 2003, 07:59 PM: Message edited by: 93EmeraldMTX ]</small>
NetNinja
Hotlanta,GA, USA
Holy Schlotzskys!
How the heck do you fix that!?
Drill out the broken part and pray that you can find a replacement?
I am getting ready to do my 120K and I pray I don't that.
I heard that the tourqe specs to the valve cover bolts is wrong in the Helms manual?
IS that correct?
Yamaha V6
SHO Enthusiast
Rhode Island
Have a couple (and only a couple) left; they're discontinued, no replacement, FYI. Email offline if interested.
Bizzy
On a side note is there an easy method to getting them out of a 3.0 block without breaking them or damaging them? I have a bare block and thats the only part that I still need to pull off the bare block.
93EmeraldMTX
East Lansing, MSU
netviper:
Hmm, good question. It didnt take much to get it out really, but i dont know if you'd want to marr up the unthreaded surface with pliers.
revhardSHO
Seattle, WA
Its just a stud right? I imagine you could match it up with an automive stud from a hardware store. If not i should have one for you.
93EmeraldMTX
East Lansing, MSU
ok, new question. how exactly did that spring go in there? i see there is the pin on the tensioner, but where does the other side go? Also, how much tension needs to be on it before i put it in?
haydenm315
Reisterstown, MD.
Yamaha V6:
A shop could always machine them if there aren't any left. Any idea what the specs are?
