Those with removed silencer cone.
V6&V8SHO
wauconda, IL
Does your car make a howling noise at idle sometimes because mine does it all the time once the revs go below 1,200 rpm. It sound like someone blowing over an opening of a glass bottle. The howling is coming right where the silencer cone used to be..
<small>[ March 25, 2003, 11:40 AM: Message edited by: V6&V8SHO ]</small>
NorthernSHO
Ontario, Canada
Well I have the whole inner box removed now but I did have just the cone removed for about 4 months and never had any such noise problems.
FASTSHOMTX92
NEW YORK
I had a simalar noise, make shore that your air filter is tightly sucured so there is no free air getting in between the filter. I put some zipties on mine
shadow102
Atlanta, GA
i have a cold air snorkel and it just sounds like a vaccuum cleaner when i first start the car up
Run a 4" duct from the air box opening down to the grill area. This will prevent any such noises.
SHO--ripper
928 Euro
winsted,CT
I have removed the silencer cone from 2 of my SHO's and never experienced that noise. I will pull the cone from my 91 soon and hopefully it won't make that noise.
rendyx
Buffalo, NY
I have heard this sound too, and wonder about it. I suspect it may be related to imperfections in my intake system. If the parts are positioned properly, this may affect the original design, and cause a strange sound. I believe my SHO has had a couple fender-benders, and perhaps this upset the system. Take for example new cars which have had fair damage - although they may look repaired, it is very difficult to make everything seal together properly again.
jthomas68
Area 51
You wouldn`t beleive the sound that comes out of my air scoop.I think it could suck in small animals if i tap the gas. :D
SHOtimer
#2910
Santa Clarita, Ca
Mine used to make that noise, before a K&N and after. I double check everything, and I don't have the silencer removed (will soon). Anyways I figured I might as well get used to it. Well, my IAB died, so I replaced it and the noise as not reappeared since the new IAB was installed 7k ago.
Just a thought, worked for me.
Doug
stevetatro
Cincinnati, Ohio
I had that noise for years. Finally had to replace my IAB (for other reasons) and the noise disappeared.
This could be the ticket!
SuperG
Houston, TX
I have the same noise, K&N Panel Filter, removed silencer cone, and replaced the IAB, although with a used one...
poffffd
