92sho16
b00sted
What is the injector offset that your running? I'm wondering if i'm in the ballpark of the being right.
It's been a while since I've messed with mine, but mine are in the ball park of 42 (high) and 58 (low). However, I have adjusted the Injector Offset to allow for this... Otherwise a ran out of room on the low slop (>110).
I would have to read my TwEECer tomorrow (got a wedding to go to right after work)... Keep in mind, the last time I adjusted it, I was having electrical issue that I didn't yet know about.
What is your offset at 12v and 14v?
This is what i was looking for. I know jason had issues with his car, i had already asked him but i thought there were quite a few people running the 48 accel's. I feel like im close because kamrf values are pretty close to 1 but when i cruise down the highway at part to no throttle the car runs like 11-13:1 afr and i havent had a tank of gas that ive seen more the 14mpg yet. I feel like i should adjust the offset until i get the cruising afr correct and then lower my high slope of 48 to get the car to not be lean at WOT.
I was having the same problem. Especially when cruising in neutral. A/F went WAY fat. I took 30% off of the injector offset value from 12v and 14v. So far it really made a difference. No pig rich part throttle, or when I shift to neutral.
Start with -30%, and see what happens.
I have already taking 30% actually a little more off and it still runs like that. What are your running for slopes?
my 47.7 (or whatever they are) i got from tim i have set at 48/85 i think and it seems to work well. idle its lean (dont really car at idle lol) part throttle and out of boost it bounces between 14.3-15.3 usually. and when in boost it goes down to 12.5:1 and WOT in boost goes to 11:1 - 12:1 usually. and somtimes richer. i cant wait till i get megasquirt...
-Mitch
