The Overheating Saga continues.
Oz
Way out front
Ok, added to the list of things that have been done:
Swapped in a 180 T-Stat.
New fan.
Took out the radiator and back/front/sideways flushed it. No restrictions whatsoever.
Also reconnected the heatercore and let it warm, and drove it a bit. No change in operating temps. Still running between 210-230.
Drove to LA over the weekend and back. It was cold outside, fortunately, but even on uphill climbs, the car never went over 230.
The AC condenser has a bit of grit in it. Nothing major. Could that be a factor?
I think I may add a double core radiator soon.
By the way, the car is sold.....or spoken for. In about a month, it will be out of here and I will be down to just the Hulk. But I really would like to get to the bottom of this before it leaves my possesion.
Cheers, oz
How much grit is in the A/C condensor? If the air can't flow through the condensor, it sure can't get to the radiator.
Oz
Way out front
Not that much, Nick looked at it and said it shouldnt be an issue. Some small pebbles, a few bent fins, etc. But thats what Im wondering. Ive given up on trying to pinpoint the problem, and am just replacing parts now. My AC system is charged.....do I need to get rid of the R12 before I can take off the condensor and clean it up?
Also, when the fan is on, I stuck my hand between the fan and the block, lots of air. Did seem to be any obstruction.
So, any ideas?
Thanks, oz
SHOLOVER
CALIFORNIA
I was going through the same dilema til I finally had a tech hook it up to his scanner and it ran right up to 212 before the fans kicked on just like every one said so i have decided to install my temp gage and sender ala autometer and get a relay to switch the fans on at my discretion. have you had anyone do a chemical test to find exhaust in your coolant yet?
jthomas68
Area 51
If you pull the a/c condensor,you have to discharge all the refrigerant,and possibly change the o rings depending of their condition.
Try disconnacting the coolant system is "sections" and blow compressed air thru the lines to check of any blockages.This is how i found the block in my a/c system.
Oz
Way out front
I see. When you say lines........the upper and lower radiator hoses have been replaced already. What else am I looking for?
jthomas68
Area 51
Try disconnection both hoses at the motor and blowing compressed air thru it.You know the hoses and radiator are good,so there may be something else along the coolant passage.
rangerj
Brunswick, Ohio
Oz,
If cooling air flow is good, and exaust flow is not hindered (no plugged cats), and the thermostat is new, then that leaves the coolant flow, lean fuel/air mixture, and dragging brakes as the remaining possibilities. I do not think ignition timeing would be an issue. Scott?
Coolant flow could be restricted by a blockage, or a water pump that is not functioning properly.
A lean mixture could be caused by a vacuum leak.
There are 9+ hoses on the intake plenum that could be cracked. If the crack runs along the clamp it is hard to detect, especially if it is on the bottom, and/or on the back (firewall) side.
The emergency brake cables could be hanging up and not fully releasing the rear brakes. One or more of the calipers could have a piston hung up and "dragging" the brake(s). If it were just one the car would "pull" to that side!
All of the above assumes that you have ruled out a head gasket leak that could be putting exaust gas (air) into the cooling system.
Is there anything else that could be putting a "drag" on this engine, and causing it to run hot, something in the drive train maybe?
Have you done a reverse flush, or "back flush", of the cooling system? This means flushing the system in the reverse of the normal coolant flow.
I feel for you Oz. These are the times that try mens souls! No surrender, no retreat, and never say die! rangerj
I added an additional cooler to the coolant lines of the oil cooler. Oil cooler coolant cooler
It is a hayden oil cooler. Coolant only flows though it when the t-stat is open so no over-cooling occurs.
