NotSoSlowSHO
Gas is $$ WALK!
I just got my SHO back together this evening. She fired right up without hesitation. Has a bit of an issue with idle, but that is easy stuff...
On to the oil leak. And the betting:
A drip, drip, drip, from one of the pan studs. The block had a bit of oil from before the replacement of seals, as did the lower radiator hose. The oil was dripping once every 2-3 seconds while the engine was running. The oil leak STOPPED when the engine was turned off.
So, where is it coming from?
BTW: I JUST replaced Cam seals, pan end seals, and oil pump to block gasket. And the sealant was good and cured.
1. Cam seals
2. Oil pan
3. other??
Im stumped. But whats worse is that I have to tear the dang thing apart again squint
My neihbors LOVED me stinking the apt complex up as it was dripping right onto the front cat. finger
Oh well, Im taking bets now
1. Cam seals
2. Oil pan
3. other??
