Thanks again Sdpatt: DIS Module
F-22 Raptor SHO
7015 feet above Sea Level
As usual, he is da man. Car was quitting while driving, not the cps (got tach response) or the fuel pump (could hear it running). Code showed a Secondary Fuel Pump Circuit Failure. Say huh???? None of the Kalamazoo SHO guru's could figure it out.
Scott's 0.02 said it was the ICM...whats that??? Ohhhhhhh the DIS module. Turns out it can give you that message if it is going bad. (thank you SHO service manual for the pic). I replaced it with a buddy's DIS to test before I bought another one. Result: drove that sucker for 400 miles this weekend and didnt have one single problem.
Scott: someday I will meet you, but till then: "YOU ROCK!!"
