nkb93
SLO 4 SHO
After installing a new timing belt on a 3.0L, I'm wondering how to set the tension. I'm guessing that when I loosen the tensioner nut, the torsion spring will tension the belt to the proper level by itself. Then, just tighten the tensioner nut to spec. Is this correct?
How often should one check/adjust the tension on the belt?
TIA-
Nate
TIA-
Nate
