teflon tape/liquid useage
I'll_SHO_U
colorado
Can anyone give me a run down on what and what not to use teflon tape on? Would liquid teflon be better? At the moment I'm replaceig the ECT sensor and it just made me wonder. Thanks.
jthomas68
Area 51
Neither should be used on fuel fittings.On nitrous fittings,the paste should be used.That`s all i got. :D
I would not use any tape if small pieces of it entering the system you are sealing is a concern.
Ishodu
Is there none on the sensor allready? When I changed my ECT there was a red sealeant on the threads right out of the box. Also when ever using T-tape never on the first two threads.
I'll_SHO_U
colorado
No there wasn't any sealant on the sensor I got. Just plain plastic. I wish I woulda read this before I got started cause I put tape on ALL the threads. I'll redo this when I figure out why the thing won't start.
I'll_SHO_U
colorado
So when I went to pull the teflon off the ECT sensor I just put on there wasn't any on the threads that were threaded in. Should I be worried that theres a little bit of teflon floatin around my cooling system?
Teflon tape will not hurt if it gets into the cooling system. Rather somewhere that has very small ports, openings or other places small pieces would plug something up.
projectSHO89
SHOless In St L
Don't worry, the heater core and the radiator make excellent filters for straining particles out of your coolant.
Steve
poffffd
