Ted B Chip
dosmoney
Swansea,MA
I will be buying a ted b chip soon, i have no experience with these at all. tough to install? and can i still send it out to get programmed? is the programming for a 1995 stock ATX the same for a 1994 stock atx (d4ui)?
any and all answers/input will be GREATLY appreciated
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Just pull down your glove box and the computer is there. Just push it in. You can have Ted reprogram it though a dyno with A/F will help when doing upgrades.
yamahaSHO
E85 whore
Arkansas
You don't just push the chip in... Most likey, your computer has never been taken out. You'll have to pull off the rear bracket and remove the sticker covering the service port. Some find it easier just to remove the whole computer. To do this, you'll have to remove the screw holding the harness to the computer in the engine bay.
You may want to use some tape to ensure the LPM does not become dislodged. You will not be able to reuse the rear bracket for the computer for installation.
I believe Ted's e-mail address is [email protected]
Axianator
I am a banana!
Roanoke, TX
To add to Jason's post - if your a chip or diagnostic tool has never been attached to the J3 port on your computer (where the LPM will be plugging into), I would recommend that you remove the computer from the car entirely and clean the silicone sealant and dielectric grease off of the J3 service port before installing the chip. Failure to do so could prevent the chip from making proper contact with the terminals on the J3 port and could keep your computer from functioning properly, assuming it even works at all.
For tips on cleaning the edge card connector, flip over to page 2 of the EEC Tuner's user guide:
http://www.eec-tuner.com/biz_html/guide.pdf
As for your compatibility Q - an LPM programmed for a '94 will also work on a '95. ;)
Axianator
I am a banana!
Roanoke, TX
While $150 isn't bad, I personally wouldn't pay any more than $125 shipped for one.
Just my two cents, though ... :cool:
yamahaSHO
E85 whore
Arkansas
Anyone selling a used one that is willing to let it go for that price. You also have to remember that if the LPM is not programmed for your computer or given mods, you'll have to pay a fee to Ted B. to reclaim the "LPM" status (to have the chip rewritten to what you need it to).
If you buy an LPM for $150 and have to get it reprogrammed, you only save around $25 versus buying it new.
Axianator
I am a banana!
Roanoke, TX
Unless his pricing has changed, a new LPM can be had from Ted for $200 shipped.
For not much more than that, though, you can have a much nicer SCT chip from Doug. ;)
yamahaSHO
E85 whore
Arkansas
No... Last I knew, Ted's (the fee explained above) fee was $25... $150 (cost used) + $25 (programming fee) = $175. New is $200.
$200 - $175 = $25 savings ;)
I figured you could put two and two together and figure out the fee was $25.
dosmoney
Swansea,MA
150 shipped is fine with me because if what everyone says is right, i dont have to get it re-programmed
shobote
Naperville, IL
The odds are that you will have to get it reprogrammed; unless it is a very lucky match for your particlular car (very unlikely), your car will run worse than stock, as you will find out when you insalll it.
dosmoney
Swansea,MA
most are saying i dont, some are saying i do!
can i get a straight answer?
its going from a 1995 ATX into my 1994 ATX. both stock
Axianator
I am a banana!
Roanoke, TX
The answer to your Q lies in how the chip is programmed. While an LPM programmed for a '95 will technically work on a '94, a chip is often tailored to make use of specific modications that may have been installed on the car in question.
What kind of mods are/were on the car that you're removing the chip from?
Bizzy
Disconnect your battery also before you remove the computer or plug the Ted B. chip in. Try also to avoid any static electricity, touch your car to ground yourself before removing the chip from its anti-static bag. The eproms are pretty tough, but better safe than sorry.
