Taurus SHO Race for Sale
HYPOSHO
Novi, MI
A 1994 available.
I am the owner since 1994, and the car has been garage stored.
The transmission was built from Vadeem. The SHO also has these features:
*Quaife LSD
*Transmission cooler
* Vortex V1 supercharger (Vadeem) that runs into a Sperco water ex-changer (you put combination water and ice in the rear)
*Ported heads
*SHOshop CAMs
*Wiseco pistons (89mm)
* TwEecer RT
*Eibach springs
*Koni struts
*Sub- frame connectors
*No CATs
*A custom made exhaust system throughout to blow out the exhaust and Borla custom tips
*Sparco seats
*Sparco removable steering wheel
*Complete race cage
*11 gauges
*Fully operational Nitro bottle in trunk
*Quick on/off switch
*Battery in trunk
*TCE performance brakes. Willwood 4 piston calipers, cross drilled and slotted rotters
*Two brake blowers
*A custom spoiler
*A Mustang front end (to let more air through)
*Two ECM
*Nitto drag race tires (legal on the street). Four race tires (Hoosier)
*A sort rod shifter
*A boost pump (a switch to cut off the fuel pump)
*A fully functional radio and CD player (located in the glove box)
*Two custom brake lights
*Accel pressure injectors (150648)
*Sway bar connectors (front and rear)
*Ford logo that light's up blue (with YOU having to install)
*Blue Tint on windows
*Full functional back set
*Photos ready at http://s1174.photobucket.com/user/mikebartkowiak/library/
Email me at [email protected]
papichulo
NY
Now Mr....... no pun intended... But throw the koolaid away...... It's gone bad.
SHOracer14
Me-0 Diffs-6
Toledo, OH
You didn't by chance have this car at the Indy SHO convention in 05' did you? I think you towed it with a white Ford Econoline?
98SF19
AlphaKennyBuddy
Florida
Might be good for a chump car race. Google Chilly Performance in Tampa.
HYPOSHO
Novi, MI
I trailer it (U-Hull). Back then it was pulled by Ford Expedition (Black). I did the race track and drag racing. I won best Ford Modified.
HYPOSHO
Novi, MI
$14,995 with that you get the whole car.
I've got a back up engine and transmission. The trans has NO Quaife .
The back up engine You have to put together. I've got everything except the block.
