After all the trouble I had in this thread -->http://www.shoforum.com/showthread.php?t=124190, I got about ten miles from home today and noticed the tach jumping around (actually looked like it was dropping out) and the car bucking accordingly. No CEL at any point.
Got it back home, pulled codes:
Initially:
539 (O) System shows voltage at PCM pin 10. Is A/C on ?
I do think the ac was on at this point
Memory:
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
215 (M) Primary circuit failure - ignition coil 1 - Ignition Systems
216 (M) Primary circuit failure - ignition coil 2 - Ignition Systems
217 (M) Primary circuit failure - ignition coil 3 - Ignition Systems
DIS was replaced trying to fix my previous problem. Also, when troubleshooting the previous problem, I was having trouble getting spark on 4 of the 6 cylinders. I'm guessing I need a coil?
Anything else you guys need to know to help me with this?
Initially:
Memory:
