T-Stat
SHOemup
Dalton, PA
Does anyone know how long it would take to change the t-stat and sending unit? Also, how much does a T-stat cost. Im pretty sure this will solve the problem of my car running so cold. Thanks in advance?
Chris Reina
"Don't drive like you own the car, drive like you own the road!"
AIM=turbochris12
93 MTX stock
emerald green
filler decals
Yamaha emblems
110k
Lund Headlight Covers
Lund Tailight Blackouts
SHO window banner
Tinted Windows (20%)
Vent Shades
Big wish list!!
fredhurderjr
www.neshospecialists.com
Ford Parts Network, RT-1112 T-Stat, $19.99; Temp Sending Unit SW-2328, $6.99.
You don't need to remove the intake to do this, although it might make it a little easier to get to. Remove the upper rad. hose, coil pack cover, plug wires off the coil pack, coil pack itself. That should get you in there close enough. Be very careful not to over-torque on the temp sender or the t-stat studs upon re-installation. Total time would be about 1 hour, start to finish.
Good Luck.
I have replaced the thermostat with removing only the air inlet hose and upper filter box lid. Universal joints and extensions on a 1/4" socket wrench help to access the two 10mm nuts. Careful, they are aluminum and don't need much torque. The water seal at the separation of the metal housings is provided by the rubber seal around the outside perimeter of the thermostat. Make sure it is installed. The total time depends a great deal on your experience and the tools available.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
9
94ShoOff
Guest
Fred, I hope you wouldn't charge an hour of labor for that at your new shop. I'm not the quickest with the wrench and even I can do thermostats in less than 10 minutes.
Steve
94'ShoMtx- finish stage 1 mods after hibernation, cobra wheels, cowl hood, matching side mirrors, IPT pillar guages, eibachs, 60K miles
91'Sho- police grill, plus spoiler, Gen 3 chrome wheels, 69K miles
87'Grand National(stock my a$$), 97'Ninja ZX7R
Wifes Rides-93'ShoAtx, 91'Corvette Conv.
fredhurderjr
Well it depends. It usually takes me that long because I'm only using one hand - the other one's got my coffee...
No, I was just trying to give a realistic time for someone who hasn't done it. It's an easy job, providing you don't break the stud on re-assembly.
One other piece of advice for Chris - do remove the upper hose, don't just fold it out of the way. You don't want to risk putting too much pressure on the upper radiator neck, and after all, it's only one extra hose clamp to undo. Not worth the risk.
T
Tommy the Greek
Guest
hmmmmmm......then I guess I have to replace my t-stat as well. On my recent trip to Montreal....brrrrrrr.......from NYC my temp. gauge read below the C mark, and whenever I stopped at the rest area it jumped between M & A. Even @ -15º Celcius it pumped out good heat.
'95 SHO ATX, 55W foglights, coneless, fishtank mod, white/mocha cloth interior, 46K, Mobil 1 10W-30, build date 12/13/94. 60K service performed on 12/21/01 @ 46,043 miles due to a leaking w-pump. (grrrr)
Below is a pic of her @ 37K miles (July 2001), overlooking the Long Island sound off Orient point, NY.
www.roushind.com
AIM: kalamos73
LIZARDKING
Arkansas
I recommend the OEM part, I've had lots of problems with AZ thermostats. Might cost a bit more upfront, but at least you will only do it once.
