Sway
marbs
Roy/Ogden, Utah
So what's the best sway bar(s) to upgrade to on a stock set up? Starting to mod my suspension and I gotta start somewhere. Also should I start elsewhere or is this a good place to start? :cool:
Ishodu
24 front might be a bit too stiff for a Non LSD. But then again its a ATX, I would say 22,24 front and a 26 rear.
nkb93
SLO 4 SHO
Charlottesville, VA
My '93 ATX had a 22mm front bar stock, and I upgraded to a gen-I 26mm rear. Much more neutral feel than stock, but still a slight bit of (safe) understeer. Love that combo.
Shoaz
Studly dood
Scottsdale, AZ
The rear is very easy to replace, the front bar is a bit of a pain and requires dropping the rear of the subframe.
