Sway bar match or mismatch.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Ok i got 2 kits right now , fr-rr sway bars from a 92 mtx. AND the fr-rr from a 94 ATX. (usure of all sizes , havnt mesured yet)
I want a good setup for daily driving , but i want some stiffness in curves but not too much. Im not a curve maniac. Will also have 300 crank hp. Will be using the 1/4 mile quite often. I will never autocross.
Any of you can offer me the best setup of swaybars for that.
Shoaz
Studly dood
Scottsdale, AZ
Then the swaybars are a total non-issue other than your street preference.
Measure what you have first. Otherwise opinions you get might be pretty irrelevant.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
well the 92 mtx is a set thing (dont remember the site with the chart) , its only the 94 atx thats the issue (they made plenny swaps)
SHOck
Louisville, Ky. USA
For a drag queen, I suggest the lightest bars possible, and maybe even elimination of the front bar, if you feel comfortable driving it on the street like that (no thanks).
Minnesho
i was wrong
MinneSHOta
there was really no rhime or reason to what size bars ford put in 2nd gens. however most of the 92s i've seen had a 24/23 rear setup. and it seems like a lot of 94-95s came with the 20.5 front bar but i've found a few with 22 front bars as well. you should measure them to know exactly what size bars you have. endl
godspunk32
'98 Sable LS
Mount Laurel, NJ
For a more drag oriented car, go with the 20.6 in the front and the 21 in the rear. The car will be neutral, although taking it on a road course (which you say you won't do) will suck.
JR
