suspension upgrades
goalieman59
Learning Slowly
OFallon, IL
I just need some feedback on what I should next. I already have struts, spring, STBs and sub frame connectors what should I do next.
Storm-Chaser
Shit Louis
Assuming you've done front and back springs/struts/braces - TPR bushings, Gen III/aluminum subframe bushings, stabilizer bar upgrade/matching. Then lower control arms and outer/inner tie rods (if needed).
blue thunder
ct.
change your front and rear sway bars. You will notice the handling right off the go, and the cornering will be unbelievable with no leaning. Turns on a dime and its still a taurus.
Installing TPR anti-sway bar bushings is the biggest effect for the buck in the suspension upgrade arena.
