Suspension Re-Vitalization...What Misc Parts are Needed?
seraphiem
Jersey Shore
Its that time to bite the bullet and spend some serious coin on my stock suspenion MTX.
Looks like a Koni/Intrax setup but I'm a little clueless on what else needs to be replaced.
Can anyone give any advice? I'm looking for a parts list of common things to replace or things that usually break during the job.
Like pinch bolts, strut mounts, and other misc parts.
Also, anywho have any input on where to buy Konis/Intrax?
Thanks All.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I would replace the strut mount bushings and bearings and the tension strut rod bushings if you can.
We will have a complete listing soon on SHOBros for it so it will be easy: Suspension
SHOtimer
#2910
Santa Clarita, Ca
Your going to want to replace your strut mounts, and the pinch bolts for each strut.
It would be a good time to also do:
endlinks
ball joints (it is a good idea to replace the bolts and nuts for the ball joint pinch joint)
and also a great time to replace all the other bushings with TPR....
Doug
