Surfing the web...
SASHO91
Zoom Zoom
San Antonio,TX
looking for some info on this do-dad...
i was just looking to see what info was out there about it... seems as though its still in R&D. But the company said that it should make 5-6psi on a 2.0 motor... worth it? i dont know... probably not on the sho.. plus the restriction.. yada yada yada... it crossed my mind a couple times, and you know it goes, you cant get a certain idea out of your head.... but enough of that...
anywho.. while i was searching for specs, if you will, on that thing...
i come across this little buggar.... was actually on the same website.
then without the tensioner arm
I was thinking , this may fit where the a/c comp. sits at. granted the comp. would be gone, :doh: and you would have to build a "cage" or custom mount thing... basically alot of work...
However, i cant seem to find the units by themselves. They are for the 350z's, and BMW's.... the kits run at 6200, or so.
Its just another idea... i mean this thing looks fairly small, and could fit there.
Granted i dont know the prie on the unit itself, but other than a custom cage/mount, and piping... i dont think this would be a bad project.... maybe even less than other kits that are out there... i mean you would have to know how to weld, and get other parts... but its been done (Kenny/ NotsoSlowSho) and is possible... if its worth it... :shrug:
but its just some food for thought.
EDIT: http://images.google.com/imgres?img...ages?q=rotrex+supercharger&svnum=10&hl=en&lr=
That site has some good info on them... and dimensions.
EDIT2: this site says that the oils system is contained... http://mzmperformance.com/Merchant2...t_Code=12001-XN001&Category_Code=nissan_turbo
(If a mod wants to move this to GD, thats cool...)
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Looks like HKS bought Rotrex.
These little guys have been arounbd for a while. I just don't know if they'll support a 3.0L engine.
SASHO91
Zoom Zoom
San Antonio,TX
found their website... (should have done that to begin with :doh: )
http://www.rotrex.com/
seems like one of the C30's would be the optimum choice... i dont know how to read a flow chart... but it looks like a turbo flow chart.. maybe someone could ellaborate on those allittle?
found some prices too...
http://www.wbtinc.com/retail.cfm
yes.. its a harley site... but they still offer the supercharger by itself.
looks like either the C30-84 for mild boost. and the C30-94 for high boost...
The only problem i see is the belt/pulley... unless they offer a different pulley... it probably wont work...
