Liquid_force
I have new front end components - BJ's, in/out tie rods, even new front tires.
I've never had any front end problems/noises to speak of.
A couple months ago I messed with the sub frame to get a/c access in order to get the shim out. At one point I had the sub frame basically just hanging there. The bushings appeared to be in decent condition.
I was not aware of any specific procedure for re-tightening the subframe so I simply tightened it back up.
Ever since then I've had a "pop" (sometimes a "pop", "pop"..."pop") in the area of the driver's side floor board mainly during braking/accelerating.
So naturally I'm guessing not knowing how to properly re-install the subframe has caused one or more sub frame bushings not to work properly.
Is there a procedure I need to follow to get the bushings to "seat" properly, or whatever it is that's causing this "popping" noise.
