Paul1990SHO
If my clutch is starting to slip, it's time for a new one right, no alternative right?
Thanks!
Thanks!
Rob94 said:You can check to make sure the self adjuster is working properly.
Dude, If you're worried about your clutch going, then why are you lighting the tires up?Paul1990SHO said:$hit not sure if I understood this at all!
I pulled it up with my foot. After that I did a tried to burn it up 1 > 2 > 3..... now maybe I am totally losing it, but I am pretty sure that there was no slippage! Is this what you are talking about? The tires don't quite light up like they used to but this could be for other reasons.
Am I nuts?
Thanks again!
91 SHOplus said:Dude, If you're worried about your clutch going, then why are you lighting the tires up?
Bizzy said:Warmer weather versus colder weather.![]()
Camarok said:Yes this is a very good possibility, stick you foot behind the clutch pedal and pull it back towards you, then push down on it.... if it didnt' change or got worse... you have the same issue I had on my mustang.... and miltownsho had on his red sho. The teeth were wearing so if you really want, take a look under the dash by the clutch pedal, and look up. There should be this blue half moon-y thing with teeth on it. (kinda hard to see, you may only see the very end of it)
What you can also try, is pull back on the pedal with your hand and push up, as in towards the roof of the car, then release pressure from the clutch pedal, and give 'er a try. Sorry for the poor discription.....![]()
