Storm-Chaser
You're going to need someone to help you. It takes three hands to: a) hold the wrench against the bolt; b) apply leverage to the wrench with the pry bar; and, c) to then turn the ratchet.
They are 17" rsl valkyrie's. This pic was with tokico and eibach combo, Thanks for the interest.Storm-Chaser said:![]()
Ghost93
Nice rims! What kind? Which spring/strut setup did you use and how far did you lower it?
Storm-Chaser said:Redline,
While I realize this was probably trying your patience pretty well :banghd:; I would like to encourage others to *not* bend the subframe mounting brackets. Everytime you "bend" metal it introduces metal fatigue and stress, making the brackets weaker and possibly resulting in failure of one of the mounting brackets over time.
So for others that may reference this thread in the future, PLEASE take the time to completely cutout the lower control arm bushing, if that's what it takes. Yes the inner sleeve is hardened steel, but cutting as much of the outer sleeve as you can and then changing to a new cutting disc once you get to the inner sleeve, will help. Damaging any of the four mounting brackets (while repairable), could eventually require replacement of the entire subframe assembly. And that's something you definitely don't want to try in the parking lot. Not to mention how many frozen bolts you will probably have to deal with in swapping-over all the suspension parts.
And for future reference, another technique to try given how far you got the bolt to back-out, would be to cut the head-end of the bolt off, then hammer it back towards the front of the car until it clears the aft-subframe mounting bracket a short distance (~3/16"). Cut a short section off the [now] protruding threaded-end of the bolt, and work it back into the bushing where it should now clear both the forward and rear subframe mounting brackets without having to bend the brackets.![]()
93shoblkmtx said:Redline how old were they, any idea?
