Struts
jenk007700
Buffalo, NY
I have seen some small discussion on struts but was wondering where/what the options are? I have a 10 PP (70k) w/ a passenger strut that is accumulating dirt. the driver is clean so I am thinking there is a leak. no drips and no other sources around there.
Thought son a set of Monroe struts be an option as I would keep my springs as they are the PP versions.
Cheers
If only replacing struts, OEM is just about the only option around. If willing to ditch the springs, you can move up to Megan coilovers.
Are you noticing any deterioration in ride? Usually the struts in the rear are the ones that give way.
jenk007700
Buffalo, NY
SHOdded, I cannot say I have noticed a ride issue. Rear still appear to be fine. My concern is clearly on the front with the oil leaking passenger strut.
