badcamelot
Hey guys need help. A few weeks ago I asked for help with alternator/batt charging issues. I've eliminated the battery as the concern (bought an optima one) and have two alternators that becnh test ok (yeah I know they 'might' still be bad) but unplugging the alt and one post off the batt I connect the test lead between the bare batt post and terminal cable to still find the light come on, it fades out pretty quick, but nonetheless with both connections to the alt disconnected it obviously isnt the alt causing the drain. Tracing it through the **** fuses I narrowed it down to the headlight and fuse block ****'s. So I then went to the fuse panel inside the car. Finally I've traced the drain to fuse #8. With that fuse left out and the **** fuses plugged back in the test lead does not light up. So I think the drain is in this circuit. Problem is this fuse (accoording to the owners manual) works with: chime key in,clock,keyless entry system,radio memory,lights for engine compartment,glove box,instru panel,interior,pwr mirror and trunk/storage area. I realize the radio should always have a milli draw for the memory etc as too with the clock, but these dont drain anyones battery. My key ignition is loose and I have to giggle it to stop chiming when I take the key out, but it does stop. Even if it didnt it only should chime and therefore draw current with the door open right?
Anyone have this issue and know what/where to check/fix/replace?
Thanks.
Thanks.
