haydenm315
I can't seem to get this right.. and am so frustrated. I thought I'd finally pass emissions today after having my bad cat replaced. My car spikes Hydrocarbon emissions on decel. I'm putting out 1.43 grams per mile hc when the limit is 1. On the graph I am under 1 gpm for the most part except when decelerating. I don't think my car is running rich all the time because I get 24+mpg driving responsibly. My thoughts are it isn't cutting off gas quick enough when you get off the gas. what could cause this?
I have cleaned my maf a number of times, along with the orange temp sensor in the airbox. I've done decarbon a number of times. My TPS sensor was replaced not too long ago. It wasn't original motorcraft though.
Within the last 5k I have done another 60k. I replaced a bad thermostat, installed a new knock and cam sensor. I also had a cat replaced. I had a bad plug wire for a while and I think it did bad things to my cat.
Pulling SPOUT last time only made my HC go up.
