Steering????
digsj7
Digsj7
Columbus ne
I have a 95 ATX and the steering wheel moves from right to left constantly! It does this at all speeds and really bad at lower speeds. Could this just be from bad tires or do I have a bigger problem? I was thinking it might be from the rotors being warped because when I slow down the vibration about kills ya!...but it does it even when your off the brakes. Thanks in advance for any help!!
FYI---I'm a noob to the forum and so far...love it! Keep doing a great job sho owners!!!:woo-hoo:
SHOspazz92
Banned
Triad Area, North Carolina.
How are the wheels bearings?
-Sam
needaQuaife
AKA: 5speedSHO
San Diego
not to jack ur thread, but was wondering if digsj7 or anyone else has same issue.
when on a sloped road, I always have to steer the opposite way, more than what I consider "normal".
wheel bearings too? and or strut mounts?
SHOspazz92
Banned
I had this same Issue...On both of our 92's. In each case, The wheels bearings were shot. With the car on the ground, See if you have any Play in the on the actual front wheels.
-Sam
digsj7
Digsj7
Columbus ne
It's whenever I drive the car...sloped road or not. I'll replace my wheel bearings and see what I get. Thanks!
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Bearings do need to be pressed, in and out. But it is easy to check them to see if they are even a problem. Just grab the top of your wheel/tire and see if there is any play.
Is it more pronounced through slow speed corners?
digsj7
Digsj7
Columbus ne
Yes it is, at slow speeds the steering wheel moves back and forth over an inch both ways. I suppose the rim and tire need to be elevated when checking for any play, right? I was also thinking that maybe a tie rod was giving me the play in the steering wheel...but then would I get the vibration with it...?
SHOspazz92
Banned
Do it while its on the Ground and the suspension has Load on it.
-Sam
Warped rotors are most likely cause - these front brakes are very sensitive to how the lug nuts are torqued - if they are not torqued properly, they will warp very quickly.
digsj7
Digsj7
Columbus ne
Welp, the cause of the terrible steering and vibration was simply broken belts in two tires. Swapped em out and vibration is gone and steering is good! oh yeah... and wheel bearings seem ok too.
