I while back I had some trouble with the steering in my 94ATX giving feed back to the steering wheel while turning (wheel wanting to go back and forth while turning)
I replaced the rack and it went away mostly, now the GD thing is doing it again!!!
If the car is running and you open the PS res there is no bubbles and you can see the movement of the fluid like normal. The pump doesn't make any noise and no leaks anywhere, I also flushed to system really well, did i do the wrong thing putting dextron mercon 3 atf in it?
Could it possibly be the thingy with the two electrical connections that bolts to the rack that the pressure hose connects to gone bad?
I haven't had the car long and it goes like a rocket but this problem makes me HATE driving it.Not to mension dangerous.
One other thing... if the tranny slides a bit then clunks occasionally going to 2 gear is it a lost cause or will a band adjustment fix it.
Thanks again
Thanks again
