Here's how it's possible: If the rear corners of the subframe fall, that messes up the whole geometry of the steering system, since the rack is attached to the rear crossmember of the subframe. Living in the sun belt as you do, you'll likely never to see this.
NHTSA CAMPAIGN ID Number: 93V106002
Component: STRUCTURE:FRAME:MEMBERS AND BODY
Manufacturer: FORD MOTOR COMPANY
Year: 1988 , 1989 , 1989 , 1989 , 1990 , 1990 , 1990 , 1991 , 1991 , 1991 , 1992 , 1992 , 1992 , 1993 , 1993 , 1993 Make: LINCOLN Model: CONTINENTAL , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE Recall Date: 12/02/1993
Type of Report: Vehicle
Potential Number of Units Affected: 1110000
Defect Summary:
VEHICLE DESCRIPTION: TAURUS AND SABLES BUILT FROM 8-1-88 THROUGH 12-23-92 AND LINCOLN CONTINENTALS BUILT FROM 10-3-88 THROUGH 12-23-92. THE AFFECTED CARS WERE SOLD OR REGISTERED IN THE FOLLOWING STATES: CT, IL, IN, ME, MA, MI, NH, NJ, NY, OH, PA, RI, VT, AND W. BODY MOUNTS AT THE REAR CORNERS OF THE SUBFRAME, WHICH SUPPORTS THE ENGINE AND TRANSMISSION, MAY BECOME DETACHED DUE TO CORROSION OF THE SUBFRAME MOUNT RETAINING PLATE. THIS WOULD ALLOW THE REAR CORNERS OF THE SUBFRAME TO DROP.
Consequence Summary:
IF ONE OF THE REAR CORNERS DROPS, ONLY MINOR INDICATIONS OF A MALFUNCTION SUCH AS A CLUNKING NOISE OR SLIGHT CHANGE IN STEERING WHEEL ALIGNMENT ARE NOTICEABLE. HOWEVER, IF BOTH REAR CORNERS OF THE SUBFRAME DROP, STEERING BECOMES VERY DIFFICULT, WHICH COULD ADVERSELY AFFECT VEHICLE CONTROL AND POSSIBLY RESULT IN AN ACCIDENT.
Corrective Summary:
INSTALL A CORROSION-RESISTANT REINFORCING PLATE AND A NEW BOLT ON BOTH REAR SUBFRAME MOUNTS.
and
NHTSA CAMPAIGN ID Number: 98V323000
Year: 1986 , 1986 , 1987 , 1987 , 1988 , 1988 , 1988 , 1989 , 1989 , 1989 , 1990 , 1990 , 1990 , 1991 , 1991 , 1991 , 1992 , 1992 , 1992 , 1993 , 1993 , 1993 , 1994 , 1994 , 1994 , 1995 , 1995 Make: FORD Model: TAURUS , SABLE , TAURUS , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , CONTINENTAL , SABLE , TAURUS , SABLE Recall Date: 12/18/1998
Potential Number of Units Affected: 2697000
Defect Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES ORIGINALLY SOLD, OR CURRENTLY REGISTERED, IN CONNECTICUT, DELAWARE, DISTRICT OF COLUMBIA, ILLINOIS, INDIANA, IOWA, KANSAS, KENTUCKY, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, MISSOURI, NEBRASKA, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, VIRGINIA, WEST VIRGNIA, AND WISCONSIN. THE REAR LOWER SUBFRAME MOUNT PLATE NUT CAN EXPERIENCE STRESS CORROSION CRACKING IF SUBJECTED TO LONG TERM EXPOSURE TO ROAD SALTS. THIS CAN RESULT IN FRACTURE AND LOSS OF THE STRUCTURAL INTEGRITY OF THE SUBFRAME MOUNT ATTACHMENT. DETACHMENT OF THE BODY MOUNTS AT THE REAR CORNERS OF THE SUBFRAME, WHICH SUPPORTS THE ENGINE AND TRANSMISSION, ALLOWS THE REAR CORNERS OF THE SUBFRAME TO DROP.
IF BOTH REAR CORNERS DROP, STEERING WOULD BECOME SUDDENLY VERY DIFFICULT, AFFECTING VEHICLE CONTROL AND INCREASING THE RISK OF A CRASH.
Corrective Summary:
DEALERS WILL INSTALL SUBFRAME REAR MOUNT BOLTS, REINFORCEMENT PLATES, AND PLATE NUTS.
It is also quite possible that the steering column intermediate shaft couplers have slipped (that 5 o'clock thing) due to the pressure applied when trying to stong-arm the steering wheel back into place. If your subframe mounts are secure, my bet would be what Scott said, the rack and that it has developed bad spots that cause sticking, then you may have twisted the shafts in the column.
Steve
<small>[ October 22, 2002, 09:29 AM: Message edited by: projectSHO89 ]</small>
