Troubled93
So 2 nights ago I started my car just to let it warm up and run as its cold where I am from (-8 that night) and according to the temp guage it was right in the middle just like usual. Well the heat was blowing cold, so I cut the engine and check the coolant which I filled 2 days prior. It was at the bottom of the reservoir (weird???) So I started the engine back up again and gave it a few 3-3500 RPM revs to see if the heat would get warmer... No Luck... then all of a sudden the engine just started steaming or smoking pure white... So i pop the hood quick to spot the source and it was coming out of the intake area on the rear bank of the engine (closest to firewall)
Could this be a blown head gasket? Has anyone had these symptoms/problems before... anybody have any ideas???
