stablizer bar question
Dr_Thompson
CT
The bolt that holds the stablizer bar to the lower control arm snapped. Im wondering, what size is the nut that holds it into place, i couldnt get a socket to fit correctly over it. How hard are those bolts to find by the way, they're all rusted and should be replaced. Im thinking ford should be able to get em easy enough.
SHO Type U
The stabilizer bar, aka sway bar, connects to the endlink, from the endlink to the strut. There are also 4 total bolts that connects sway bar to the subframe via sway bar bushings.
The only thing that connects to the lower control arm are the strut rod, the spindle and the sub frame.
