Stability control disable
Frank P
USA
Just looked at my 2015 and I have neither the Auto Park or traction switch, just a blank space where they should be. I do believe that I can access the traction control via the dash display.
Should there be a switch if using the display to turn it off?
Auto Park was an option. Not every SHO came with it. It seems only certain cars came with traction button. Mostly PP's.
Charles Ferrigno
Detroit
My 19 only has a pocket there that is too small to hold my phone. I think I will open up my console and see if I have the harness there.
Lostneye
NY
Auto Park by itself was only on the 2013 and could be had on PP cars. After that it was a package with adaptive cruise and not available on PP. Only PP should have the traction button although it seems now and then someone pops up with one that doesn't.
"Now I Know". Thank you sir.
jmr061
WI
That points to the correct switch (for Auto Park and Advance Trac) being DG1Z-13D730-CA since that switch is only available on the 13.
Frank P
USA
I may have one of the PP's that doesn't have the switch. The paperwork I received listed performance package as well as coming with 20" wheels, which I was led to believe was an indicator.
So that is the second car with this issue.
jmr061
WI
This was discussed years ago. There are many out there with the wrong switch.
jmr061
WI
My old 13 had the right switch but was an early build (133xxx) and wouldn’t go into full off mode because of the firmware in the cluster and ford refused to correct it. All of them that were early builds suffered from this. So they couldn’t get it right either way.
My 13 is #105248 and everything works including completely disabling the Advancetrac.
GUSTAVO CORNEJO
houston
sir your are on the money thank you!!!!!!!!!! Ijust have the parts department pull the part thanks a million:):):):):)
jmr061
WI
So all three functions work? TC OFF, SPORT MODE and ADVANCETRAC OFF?
Do you have the ability to pull the cluster info?
See if it is part # DG1T-10849-EJ with software of DG1T-14C088-BH and DG1T-14C026-BJ.
Sport Mode is activated by the gear shift.
I press the button once, TC is turned off. I hold the button down while depressing the brake for 5 seconds the AdvanceTrac turns completely off.
Lostneye
NY
Double tap is Advance Trac sport mode. It dials back how the car intervenes.
Charles Ferrigno
Detroit
I tried this and it didn’t work for me. So much for my non-PP to act like this. I will try to install the switch and see if that works. Anyone ever hear of installing the PP software on a non PP vehicle?
